Re: Allan or others. HELP PLEASE
Posted by TractormanNC on July 20, 2009 at 08:46:19 from (209.42.190.202):
In Reply to: Allan or others. HELP PLEASE posted by Jerry Gilliam on July 20, 2009 at 07:04:10:
Yes you can use the ports to feed a separate loader valve but you will have to tie the tractor remote valve in either extend or retract position to get flow to the loader valve. In addition unless you make the connection with quick couplers you will lose the use of that remote for anything else.
If you are already using both remotes for the loader, You have two other choices.
1. a power beyond block used to be available from CIH $$$$$. Don't know if still available. maybe aftermarket.
2. a Fasse valve which allows one remote to be split into two outlets. Electrically switched. cannot use both at the same time.
HTH
