Re: 656 draft control reassembly
Posted by karl f on July 20, 2009 at 10:26:56 from (209.188.106.159):
In Reply to: Re: 656 draft control reassembly posted by Allan In NE on July 20, 2009 at 03:38:40:
Allen--
gotta pull the cylinder out of the way anyhow to get at the standpipe more easily. It is in the rear under the casting over the rockshaft--above the top of the photo. the tall drain plug is in the front left (would be the lower right of the picture--it"s absent in the sample pic), but i think want all the oil to drain out the rear standpipe hole as designed with or without the pipe in place.
this begs another question: how is the differential lubed? the parts diagrams show a manifold, and i"m wondering where that gets its oil supply. If it is the standpipe i definitely want the oil going where it is supposed to, since this tractor is still used for heavy drawbar work.
thanks
karl f
