Don't cut into the pressure lines from the pump. This is an open center system and as such it can only have one path for the oil to go from the pump to the sump.
If you tee off from the pump lines, you will need a cockamaime arrangement of ball valves to make anything work at all. You won't be able to use the loader and the remotes at the same time like you want.
The oil has to come off the pressure side of the pump and go through all the valves, one after the other. That's what a power beyond plate does. It puts your loader valve "in line" with all the other valves in the system.
Cut into the lines, and the oil has two paths. It will always take the path of least resistance. Use a loader valve, and the oil will flow through the remote valves. Use a remote valve, and the oil will flow through the loader valve. It won't be pretty.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
