Posted by Owen Aaland on July 20, 2009 at 14:07:49 from (65.174.247.87):
In Reply to: Farmall M clutch posted by jeff338 on July 20, 2009 at 11:44:10:
Do not do any adjusting on the levers on the pressure plate. If they were OK with the old disk they will be OK with the new one. Unless you have the proper equipment to adjust them they are most likely adjusted closer to what you want than you will be able to do.
With the new clutch installed the levers should be pretty close to parallel with the surface of the flywheel. If the levers are real close to the pressure plate cover, the disk is probably in backwards. If the levers are in the near parallel position just adjust the free play on the clutch rod and you should be good to go.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
