Re: Do all F-20's run rough without a load ?
Posted by BruceS. on July 20, 2009 at 17:54:23 from (76.15.41.19):
In Reply to: Do all F-20's run rough without a load ? posted by Pete in Holland, MI on July 20, 2009 at 12:36:22:
My F12, 20s, and 30 all idle as good as a well-tuned H or M. I do have to back off of full spark advance, but only slightly, not so the exhaust gets throaty. My F series motors have had new valves and hardened valve seats, new valve springs, good hot mags, timed by the book, carbs cleaned out and adjusted according to the particular engine. When under load, it's full advance for max power.
