Re: VAPOR LOCK??... 1486 IH
Posted by Bob M on July 20, 2009 at 18:27:09 from (74.74.133.11):
In Reply to: VAPOR LOCK??... 1486 IH posted by Ron Bailey on July 20, 2009 at 18:03:12:
Ummmm.....diesel engines are not susceptible to vapor lock(!)
More likely your problem is a failing starter. Does the engine run OK warm and coast down normally when you shut it off?
If it does your starter is losing power when it gets hot. Be looking at the starter and possibly the starter power circuit wiring.
