Re: C clutch
Posted by Owen Aaland on July 20, 2009 at 18:33:51 from (65.174.247.87):
In Reply to: C clutch posted by Russ from MN on July 20, 2009 at 17:38:38:
As the clutch disk wears the pedal will be closer to the platform before it engages.
You can use the adjustment on the rod to set the engagement point where you want. Just make sure you have at least an inch of free travel at the platform and that the clutch completely disengaged when depressed. If you keep it between those measurements just put it where it is comfortable for you.
