Re: Farmall SM Hydraulic Control Valve
Posted by TractormanNC on July 21, 2009 at 11:40:32 from (209.42.181.215):
In Reply to: Farmall SM Hydraulic Control Valve posted by Yardjockey on July 21, 2009 at 10:37:59:
Sorry to be the bearer of bad news but it sounds as if your control valve is worn out. IIRC there is only one O ring in the double acting valve and it is to seal oil from leaking out. Sounds as if that is worn out also. You would think they would last longer than 55+ years.
