Re: Farmall M clutch
Posted by Owen Aaland on July 21, 2009 at 12:20:11 from (65.174.247.87):
In Reply to: Farmall M clutch posted by jeff338 on July 20, 2009 at 11:44:10:
Where is the mechanism bottoming out? If the outside of the clutch shaft hits the clutch housing before the bearing touches the levers you have a linkage problem. The release fork is timed to the clutch shaft by two thick washers that the bolts go through. Are they in the proper place?
