Re: What is this part?
Posted by Szrachnor on July 21, 2009 at 22:10:56 from (68.118.187.9):
In Reply to: What is this part? posted by Michael Price on July 21, 2009 at 20:55:40:
The original chassis wiring only shows 3 sending units on the engine of that tractor:
3224405R91 Indicator Switch Assy, Air Cleaner Restriction Indicator, On Air Cleaner Mounting Bracket
91450C1 Pressure Switch Switch Assy, Engine Oil Pressure, On Top Of Oil Filter Base, Replaces 3129031R91
3073787R91 Transmitter Transmitter, Water Temp, Ac Delco, Use Only W/ac Delco Gage 3132240R1, Located On Water Pump Carrier, Or
3127956R1 Transmitter Transmitter, Water Temp, Icknield, Use Only W/icknield Gage 3127959R1, Located On Water Pump Carrier
-Leon
