Re: Farmall M clutch
Posted by Owen Aaland on July 21, 2009 at 22:55:35 from (65.174.247.87):
In Reply to: Farmall M clutch posted by jeff338 on July 20, 2009 at 11:44:10:
Instead of using half moon keys between the clutch fork and shaft there are heavy washers that fit into the shaft the same as a key would. The cinch bolts on the fork go through these washers to hold them in place. If they are missing the fork can turn on the shaft and you will not be able to maintain proper adjustment.
