Posted by Theman on July 22, 2009 at 08:39:44 from (63.107.135.35):
In Reply to: M radiator fan posted by Henry Retter on July 22, 2009 at 08:19:39:
The 'bolt' has a taper to it and can only come out the way it went in. What I do to remove the stubborn bolt is to place a short socket over the head end of it that clears the OD. Then, with the nut backed out flush with the end of the threads, use a 6-inch C-clamp to press it until the nut bottoms out. Being tapered, if it moves a little it becomes loose and can then be tapped out using a punch. Beating and/or heating is not recommended because the packing is too close.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
