Re: IHC 464
Posted by Bernard le mecano on July 22, 2009 at 16:03:29 from (75.158.246.207):
In Reply to: Re: IHC 464 posted by jimb2 on July 20, 2009 at 20:20:06:
Hi Jim, change the shaft for a shaft with 1000 RPM splines and the cover with the hole for the seal. You have to drain the oil, remove the cover to access to the PTO clutch pack, remove the roll-pin that secure the pack and pull the shaft out. Bernard le mecano Quebec Canada
