Posted by El Toro on July 22, 2009 at 17:15:58 from (64.12.116.73):
In Reply to: farmall C magnito posted by Dave Schumacher on July 22, 2009 at 15:10:50:
Make sure when you decide to do this pull the cap off the mag & see where the rotor is pointing & make a sketch so you don't forget. THEN DON"T MOVE THE ENGINE. Point the rotor on the distributor to same position shown in your sketch and then install it. This way you won't need to bring No1 piston to TDC on the compression stroke.
Then you will need to run a hot to an ignition switch, then to your coil & if you're still using the 6 volt + ground on your battery the wire from the + terminal on the coil needs to go to the points. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
