Re: 140 Ground Question
Posted by BMD on July 22, 2009 at 18:35:43 from (65.254.172.6):
In Reply to: Re: 140 Ground Question posted by Hugh MacKay on July 21, 2009 at 02:51:52:
Serial is 58845. Should be 76 model. It has key start switch and 12v generator.
What I need to find out is where the ground connection for the front lights is attached to the frame. It either corroded or broken loose failing to provide a good ground for the front lights.
Failing to find the connection I am going to splice into the ground wire and run a new ground to frame somewhere convenient.
thanks
BMD
