If you changed the pump position that much most likely the pump is out of time.
With the engine not running the the rear timing mark should be about the middle of the access opening in the pump housing. Roll the engine over by hand in the direction it normally runs, clockwise, and stop at three degrees BTDC. At that point the two marks should line up. If you do not see the front mark turn the engine one complete turn and recheck. After you make a timing adjustment turn the engine two complete turns to verify that it is correct. Only turn the engine clockwise to check the timing. If you turn it counterclockwise the marks will not line up the same due to play in the gears and pump drive.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
