Re: What Dwell/Tach to use on 6 Volt System
Posted by Allan In NE on July 23, 2009 at 06:52:47 from (148.78.100.118):
In Reply to: What Dwell/Tach to use on 6 Volt System posted by RICHMONDRON on July 23, 2009 at 06:46:28:
Depends on what you're measuring.
Dwell is a measure of time and the meter uses it's internal battery for that function. Will measure either system equally.
The tach on the other hand is measuring voltage and would need to be able to "interpret" the difference between 6 and 12 volts.
Allan
