Posted by mattofvinings on July 23, 2009 at 07:51:51 from (67.142.161.36):
Any last minute advice before I pull the sleeves out of my 340's block?
I am on the way to pickup some threaded rod, 3/4".
I've machined up a puck which pilots into the bottom of the cylinder bore, this is 1/2" thick and is not larger than the sleeve's OD so it wont drag/bind if I am still pulling by the time the puck gets to the inside of the cylinder case.
I have a 1/2" wall-thickness ring that clears the flange on the top of the sleeve and a heavy 3/4" thick bar which spans across the ring. The ring is 2" tall...so theoretically I can pull upwards for 2" before my puller goes solid.
I plan to use 80W90 to lube the hex nuts and threaded rods doing the heavy work.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
