Re: 13.6-38 tube leaks, can't find it.
Posted by CGtractor on July 23, 2009 at 07:57:52 from (69.50.45.97):
In Reply to: 13.6-38 tube leaks, can't find it. posted by SDE on July 22, 2009 at 20:46:17:
Some leaks won"t show up when the tube is outside the tire because you can"t build the same psi that you can inside the tire. I had a similar incident where I couldn"t find the leak. It would stop leaking when it got down to about 3 or 4 psi. Turned out that an inferior patch job (mine) was leaking from under the patch when at the higher psi attainable inside the tire. Bought some real patches ( the first one was a bicycle patch because that was all I had at midnight) and problem was solved.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
