Re: 806 front end threads
Posted by The tractor vet on July 23, 2009 at 19:10:36 from (76.212.231.121):
In Reply to: 806 front end threads posted by Mazemeister on July 23, 2009 at 17:45:12:
Keen Serts simple to use and stronger then any Heilicol , Standard drill bit standard tap screw in with your fingers use the tool to set the locks and it is there nver to come out and if you strip it out you just use a standard drill drill out the locks and unscrew and screw in a new one
