Re: Farmall 400 tuning problem
Posted by CNKS on July 23, 2009 at 19:23:38 from (216.144.104.128):
In Reply to: Re: Farmall 400 tuning problem posted by teddy52food on July 23, 2009 at 06:44:10:
Unlike the earlier tractors; on the Super H/Super M -- up, the max setting is 5 turns out, meaning the tractor will likely run ok if the screw is removed and the hole plugged (I haven't tried it). Thus it is similar to the fixed jet on the C113/123 carb, except that it can be adjusted for lighter loads and better fuel consumption. The carb simply needs a good cleaning, it is too lean. However, if the tractor is not used often under full load, 5 turns out is too much -- carbon accumulation.
This post was edited by CNKS at 19:26:16 07/23/09.
