Re: 656 Hydro Problems
Posted by Allan In NE on July 24, 2009 at 03:21:09 from (148.78.100.118):
In Reply to: Re: 656 Hydro Problems posted by theponyroper on July 23, 2009 at 17:57:19:
Capping the lines off at the transmission helps you determine if the problem is upstairs in the control unit or down in the transmission itself.
If the capping of the lines should by change CURE the slip, then the problem more than likely lies in the capsules in the hydraulic control unit above the battery.
Allan
