Re: 3 point on 140 ?
Posted by NawlensGator on July 24, 2009 at 07:56:26 from (52.129.12.48):
In Reply to: 3 point on 140 ? posted by Badger Bob on July 24, 2009 at 05:02:12:
I have after market 3 pts on 2 140's. You will lift the front wheels off the ground before you exceed the capacity of the 3 pt. I use a IH 1300 sickle mower and a disc with 16 blades at 18". These are in the 600 to 800 lb range. That's about the upper limit of functionality.
