Re: IH 656 gas
Posted by hoppy50680 on July 24, 2009 at 10:16:14 from (75.104.160.36):
In Reply to: IH 656 gas posted by Janicholson on July 23, 2009 at 18:56:02:
thanks again to all of you for your help. I will have to check for a plugged up idle passage and perhaps soak it in the carb cleaner again.. on the main jet issue I was going to try to go from the solenoid to a manual one. went to the IH dealer here and that needle is no longer available. while I was there an older mechanic happened to come up to the counter for a part. He told me that the reason they went to the (solenoid fuel shut off and main jet), was when that tractor first came out the farmers were setting it way too lean and they kept burning the valves out. I suppose that was warranty work. anyway the company killed two birds with one stone, it kept anyone from setting it too lean and also stopped the dieseling.
