Yes, there is an adjustment. Look closely at the rod going into the housing and you see the adjusting nut, it's pretty straight forward.
We had to machine the both the outer and inner housings to get a flat surface for the discs. Also, we milled .010 - .012 off the mounting surface of the outer housing to make up for the wear and machining.
Once we replaced the discs, springs, balls, and one actuator set; our SMD stops on a dime (a big one, but at least it stops now). It was only about a $600.00 repair!
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
