1) Most any generic or IHC light switch will work just fine REGARDLESS if youre at 6 or 12 volts because its voltage withstand rating is way higher then 12 volts let alone only 6, and similar, if youre at 12 youre probably drawing less current for lights then if at 6.
2) I would simply (also cheaper) replace all the lights with 12 volts versus using two 6 volt lights in series or some sort of ballast resistacne or solid state voltage regulators to obtain 6 volts.
3) Yes the same 12 volt battery will work regardless if you stay with an alternator or 12 volt generator and 12 volt Voltage Regulator, but be sure to Polarize the genny before start up.
4) If it has a coil igntion and youre at Neg ground, the coils + wires to the switch and its -to the distributor.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
