Re: farmall cub clutch won't work properly!
Posted by loko17 on July 25, 2009 at 15:58:22 from (204.111.113.76):
In Reply to: farmall cub clutch won't work properly! posted by jrgkribel on July 25, 2009 at 13:36:51:
If you have checked the clutch pedal free play and adjusted it to the factory specs, it should be OK. Then you have to look at the part(s) you replaced. Good stuff or chinese crap? Finally, did you put the clutch plate in with the proper face towards the flywheel? I'm not sure on the Cub but on some other tractors and on many cars and trucks, there is a "right side" and a "wrong side". I have put a clutch plate in incorrectly and had to "do it over again". I have a Cub (and many others but lets not get the better half riled up) and it shifts well on the run but I do have to shift slowly and let the RPMs get to the proper range before making the shift. Anyway, just a few thoughts and LOL!
