Re: farmall cub clutch won't work properly!
Posted by Ed pap on July 25, 2009 at 17:49:00 from (74.33.237.112):
In Reply to: farmall cub clutch won't work properly! posted by jrgkribel on July 25, 2009 at 13:36:51:
I would say your Pilot bushing is sticking. there should be a brass bushing in the end of the crankshaft. you would have to split the tractor again to check it, but I would bet money that it is gauled to the clutch shaft. you can pack a small amount of grease in the bushing before you put it back together.
Good Luck Ed
