Did you adjust the height of the 3 release fingers after installing it? They are not preset. Also you should check the clutch shaft to see if it's bent. You might be able to see through the inspection hole but the best way is to split the tractor, spin the shaft and watch it in relation to the throw out bearing.
-Leon
This post was edited by Szrachnor at 19:42:21 07/25/09.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
