Re: farmall cub clutch won't work properly!
Posted by Szrachnor on July 26, 2009 at 05:29:36 from (68.118.187.9):
In Reply to: farmall cub clutch won't work properly! posted by jrgkribel on July 25, 2009 at 13:36:51:
To remove the pilot bushing I use a slide hammer with the singer finger that screws right onto the shaft. If that's not available, I get a hack saw blade and saw it out.
If the clutch disc were in backwards it would have wobbled on the flywheel when you installed it. The "tall" end of the hub goes away from the flywheel.
To measure the finger height the service manual tells you to measure 2-7/32" from the friction face of the pressure plate to the release bearing contacting surface of the fingers. I did some measuring and reworked a more likely way to adjust it. Measure from the center hub of the clutch disc to the release bearing contacting surface of the fingers and make it 1-21/32". You can adjust the height with the screws and lock nuts on the pressure plate where the fingers attach to it.
-Leon
