That would be a starter solenoid. Basically, when you push whatever you have for a starter button, it triggers a relay within the solenoid body to allow current to flow to the starter. Not sure where yours came from, but the wiring concept is the same as what was used on Hs and Ms.
Originally, your starter would have been actuated by a rod, similar looking to your choke rod, which, when pulled, would pull a cam down and depress the starter switch, which was a button mounted on top of the starter. What looks like the hot wire from your battery and the smaller wire probably back to your ammeter on the left-most stud in the picture would have been mounted to the top of the switch body, with the very simple, normally-open switch closed by pulling the rod making the necessary contact for turning instead of the solenoid. Could be any number of reasons it was replaced with a solenoid -- failure of the original switch, wanting the convenience of a push button at the seat instead of the pull-rod . . . who knows?
You can't rule out the solenoid being the source of your short, but if your starter is behaving normally, I'd look elsewhere first.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
