Thats fine, therefore its indeed possible to by pass the ballast for a hotter starting spark as I described HOWEVER thats probably not needed and a non issue in starting a little easy to cranck C at 12 volts......
If it still uses the mechanical saddle mounted push to start switch right on the starter, that solenoid isnt need other then it still breaks/opens the big main battery cable feed to the starter (assuming the solenoids output goes right to that saddle switch) so to NOT use it you could simple by pass jump around it (in and out tied together)
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
