Re: 1951 H, Replace front seal/bearing though belly opening
Posted by TomH in PA on July 26, 2009 at 16:01:04 from (67.142.130.44):
In Reply to: 1951 H, Replace front seal/bearing though belly opening posted by rrolsbe on July 26, 2009 at 15:44:30:
It isn't hard to remove the transmission cover, and you'll probably end up taking it off anyway if you want replace the pilot bearing. The tough part is dropping and replacing the liftall and getting the clutch shaft apart.
An IH dealer is a good place to get the parts.
This post was edited by TomH in PA at 16:07:26 07/26/09.
