Re: Farmall m transmission gearshift will not go side to ...
Posted by TomH in PA on July 26, 2009 at 16:13:44 from (67.142.130.44):
In Reply to: Farmall m transmission gearshift will not go side to side posted by allan Kropelnicki on July 26, 2009 at 15:56:25:
Are you sure it's in neutral? It sounds like it's also in some other gear besides the two you can shift into. Take the shift lever out and look inside at the rails to see if one is out of place when you have it in neutral, that happens a lot with old Farmalls. You'll need a long screwdriver or small pry bar to get it out of gear if that's the problem.
