If you're losing air pressure when the pistons are at TDC on the compression stroke either the valves are leaking compression or the rings & sleeves are worn. Is the valve clearance set at .020" cold? Has this engine ever been rebuilt? Hold your hand over the throat of the carburetor while someone makes an attempt to start the engine. If there's very little suction on your is a good indication of low intake manifold vacuum which is determined by good rings, sleeves & valves seating without any leakage. You may need to pull the head and have a good shop to go over it. Measure those sleeves to see if they're worn. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
