Re: Ground bore Farmall M engine block
Posted by El Toro on July 27, 2009 at 04:23:48 from (64.12.116.73):
In Reply to: Ground bore Farmall M engine block posted by GertM on July 27, 2009 at 03:56:40:
You need to know what the engine serial number is since 2 different size crankshafts were used. Hal
2.7475-2.7485" prior to SN 278050
2.8075-2.8085" starting with SN 278050 & up.
