Re: Ground bore Farmall M engine block
Posted by GertM on July 27, 2009 at 04:33:11 from (86.89.136.158):
In Reply to: Ground bore Farmall M engine block posted by GertM on July 27, 2009 at 03:56:40:
El Toro,
Thanks for quik info.I have these crankshaft info already out of IH-8 manual and the info as mentioned by you are the sizes of the journals of the crankshaft.The crankshaft is OK and are the sizes as mentioned,I need the size of the groundbore of the engine.So the orginal size of the hole in withc the 3 bearings are mounted.The tractor with witch I am busy is a rather strange one and not much of any good left but it's an MV with all possible attachments but hard life.
