The compression rings may be stuck in the ring lans on the piston. The only way you can determine that is to pull a piston with low compression. When the engine spins freely after it warms up is a sign of low compression and the rings, sleeves and valves are all related in order to have good compression. Your engine probably needs to be completely rebuilt. Hal
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
