Re: im really stumped with this M
Posted by old on July 27, 2009 at 09:23:41 from (4.244.57.189):
In Reply to: Re: im really stumped with this M posted by linemanfarmer on July 27, 2009 at 05:20:33:
Sticking valves will cause that type of problem as will one cylinder not firing and putting raw gas in the manifold. I would check compression and see if all of them have what they should. Also if it has sat for a long time sticking rings rust etc. can cause funny problems. If it sat a long time did you put oil ot MMO or ATF in the cylinders before trying to start it?? If you didn't you could have broken a ring or a few other bad things
