How close is close when you talk about the rotor being close to #1? And which way, past or coming up on #1. If coming up your timing may be retarded too much. Do you have the correct cap?
Could be the timing weights in the distributor. Could also be you lost a tooth on the cam gear, in which case a) your valve timing could be off as well as the spark and b) you don't want it to run as that tooth can make a real mess running around in there.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
