Re: This is a weird one......
Posted by Janicholson on July 27, 2009 at 13:59:15 from (199.17.55.131):
In Reply to: This is a weird one...... posted by Dellbertt on July 26, 2009 at 12:58:25:
The crank endplay can make the difference. I would put a clutch type starter drive in it to make it work with the end play. To check endplay, put a dial indicator on the edge of the front pulley. Set it to be aligned with the crank center line. (front to back on rim of pulley) Now push forward on the pulley with a flat bar, then rearward with against the hand crank stub. read the total difference. Normally it is about .004 to .006" if more like .020" it is worn and probably could use a new thrust bearing (main bearing) on the crank.
JimN
