Re: H radiator
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Frog Level on April 17, 2000 at 05:48:06 from (152.3.34.218):
In Reply to: H radiator posted by mark on April 16, 2000 at 19:46:56:
When I recently took the radiator off my H, one of the cotter pins broke off - both ends. I ended up just getting a wrench on the nut (no easy job itself) and the pin must have sheared off at the threads because the nut came off. And my 1944 H does not have access holes directly under the nut so you have to get a open end or box wrench on the nut from the side. I ended up buying a box end ratchet, and it had to be a thin one, not the ones that look like they were made as a sandwich. Getting the radiator off was by far the hardest and most frustrating job in tearing tearing down my H (so far).
Post A Followup
: Re: Re: H radiator
