mattofvinings said: (quoted from post at 03:39:36 07/27/09) The seal and a speedisleeve probably isn't too bad. I think I might try that first unless I was convinced by other evidence that the bearing was bad.
The difficulty on the bearing probably depends on how much press-fit was used...and...you'll probably have to concoct a puller and a pusher to install it without damaging the new one.
Thanks for the reply. I am pretty sure the bearing is shot because the shaft shown in the picture has considerable play. I assume there is also a bearing/seal associated with the part that spins underneath the shaft (not sure what it is called, maybe counter rotating shaft?) I have a puller that I think will get the existing bearings out but getting them back in could be a problem (as you suggest). PS, I have a service manual on order maybe that will help me understand what I am up against and give me the part numbers for the bearings/seals and gaskets needed to perform this work.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
