25 amps output is higher than stock IH gens. Check its serial number to find out if it is OEM. If it came from a unit that used a Higher output Gen it probably had a higher output Capacity regulator. I can't tell you a part number, but there should be several available that would work. "A" type generators are wired the same, so heavier duty would make little difference in operation, but would probably last longer. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
