The earlier 706 had a lighter wishbone where the fast hitch forks go in. The later 706, with flat top fenders and longer hydraulic levers, have a heavier wishbone. But either way, if you are over 60 or hate jacks and jacking up equipment, you will love a fast hitch. Be sure to get the drawbar for it. You will never use a jack again. As for 2 to 3 point adapters, there are 2 different types. One type uses individual forks and then you buy the 3rd arm plate that goes above the pto. Be sure you get the correct plate. Some were made for semi mounted plows that didn't require any real strength. As I recall they only had one hole. The correct plate is cast with 2 holes. The other type is a one piece unit with forks and 3rd arm all in one piece. These don't look very heavy but I have lifted an 8 row flat fold cultivator with one on the back of a 460. It made the tractor a little light in the front end though.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
