Posted by Janicholson on July 28, 2009 at 19:16:21 from (64.61.211.248):
In Reply to: 1941 farmall h posted by Russell Grieff on July 28, 2009 at 15:25:40:
Decals are readily available. The sticker said to put gasoline only in this tank. (it may have said additional things). The Switch is made by closing the shutters in the front of the radiator, and possibly if cold out adjusting the manifold heat control, then turning on the gasoline tank to the carb. Then starting the tractor as normal on gasoline. After about 6 to 10 minutes of getting to the field or such, it will be warm enough to run on distillate (switch the tank valves)(don't do this unless you are demonstrating it, the fuel is not available, it is not kerosene, and would need to be blended to get even close) Close attention must be paid to engine temperature as they run best near a boil. To shut down, the tractor is idles for a few minutes to cool it some, and then run out of distillate by shutting the distillate valve and letting it run out of fuel. JimN
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
