If it has power steering one way but not the other it is not the pump or relief vave. I would check the splined knuckle on the front end of the steering shaft. Those splines cannot be froze to the steering valve input shaft. That input shaft has to move laterally in or out as you turn the wheel left or right. That input shaft moves the control spool inside the control valve. If that knuckle is froze to the input shaft and the u-joint at the suport bracket mounted to the starter is not adjusted correctly the snap ring on the upper end of the steering shaft will limit the lateral movement of the steering spool and cause the problem you are experiencing. Chuck
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
