Re: Farmall C charging system will not work
Posted by burnsg2003 on July 28, 2009 at 20:57:06 from (205.188.116.73):
In Reply to: Re: Farmall C charging system will not work posted by Pickel on July 28, 2009 at 18:20:24:
Not sure if you have a C or M.IF you have polarized the system and it is not working you may have the problem I had when I replace everything. Where the generator bolts on clean some paint off and make sure you have metal to metal contact. I was not grounding because when things were rebuilt they had cleaned and painted everything.
