Re: Case IH 5250
Posted by Allan In NE on July 29, 2009 at 04:40:56 from (148.78.100.118):
In Reply to: Case IH 5250 posted by haymaker421 on July 29, 2009 at 04:01:44:
This is a generic answer because I don't know your tractor.
However, that symptom is "usually" caused by a bad coolant level sensor at the radiator. Unplug the sensor and see if the flashing stops?
Allan
