Re: 300 utility alternator
Posted by JMOR on July 29, 2009 at 06:58:03 from (72.181.158.237):
In Reply to: 300 utility alternator posted by BruceS. on July 28, 2009 at 19:08:09:
Janicholson said: (quoted from post at 09:27:39 07/29/09) From My understanding, (and others posts) there is a range over which it works. Probably need input on the limits. Jim
12v/150=0.08A.
'Side marker' like bulbs, such as #194 are 0.3A and some of the other small bulbs often mentioned such as # 53, 1815, 57 run from 0.12A to 0.24A and the 1976 Chevy used a resistance wire in the harness with 10 ohms resistance 12/10=1.2A..........so, it appears that a wide range will work, after all any field magnetism will generate something and after that the trio takes over and it sort of bootstraps itself.
